| Rally Fighter Skin https://www.oldcabrones4x4.com.ar/foro/viewtopic.php?f=2&t=415 |
| Autor: | Tito Pereyra [ Vie, 05 Jul 2013, 05:29 ] |
| Asunto: | Re: Rally Fighter Skin |
Exterior Hardpoints Overall Length: 189 inches (4800mm) Dual Ride Height (Manual Capability) Overall Height: 69.25 inches (1759mm) High ride height 61.25 inches (1556mm) Low ride height Overall Width: 80 inches (2057mm) Wheelbase: 115 inches (2921mm) Track Width: 69.5 inches (1765mm) Curb Weight: 3,800-4,000 lbs. Chassis Construction: Tubular steel space frame Front Suspension: 18″ travel, independent double A-arm Detachable Stabilizer Bar Spring System - Long travel coil-over shock absorbers Rear Suspension: 20″ travel, 4-Link solid axle 9 inch Lug Pattern: 6 x 5.5 Steering: Power assisted rack and pinion Brakes, Wheels, Tires Brakes: 4-Wheel disc brakes Front: 13.9″ ventilated – dual-piston floating Rear: 13.9″ ventilated – single-piston floating Wheels: 17″x8″ aluminum alloy Tires: 275/70R-17 (High Ride Height) 265/50R-20 (Low Ride Height) Drivetrain 6.2 Liter, V8 Engine Automatic Transmission 430 Horsepower @ 5,900 rpm 424 lbft @ 4,600 rpm Rear Wheel Drive Approved as 50 state emissions-compliant Esto me lo agrego un amigo, para darme manija en otro foro. |
